villiers E30 4 stroke year 1964
well it under the shed and been getting stuck into tarting it up
heres the pics of work so far
fuel tank/ culinder before solder repairs and filling in the rest of the pitts and dents and the holes were all on the top of tank only
the dark blue top coat on the repaired tank
scrapped silvers blues and all colours of spray off the cowlings ,back to just a fin remains of the oxide coat just waiting for a dry day to sand back to good tin and panel beat the biggest of the dents and waves ,then fill the remaining in
the part number and ajh makers year stamp 1964
the original blue under all the crap and id plate
primmed and ready for top coats later
block masked up and now primmed ready for the topcoat when the paint arrives
the new fuel pipe i made the other night
and the mag is now back together and belting out a cracking spark
the paint is left on at this time until the other paint arrives for colour comparison as its on the hidden side of the mag
the original date for the magneto is 7/1967 ,so it looks like i was i storage for some time before the mag was fitted for shipping out of birmingham to customer or agents
and the starting shaft before stripping back ,its ready fot the primmer now, and then see what colour i pick when rebuilding the parts again
Re: villiers E30 4 stroke year 1964
my little just turned 3 yrs old forman, picked the colour off the shelf , shoock the can,got a flathead screw driver of the tool board, opened it ,got a brush out the shed draw ,mine is out of her vision level ontop of head lol ,bless,and painted all the sump off her own back ,and no paint on her cloths,thank god,thats what happens when dadda dont shut the child gate correctly, but very impresses with her learned from dadda skills and what goes were in my shed knowlodge, it was going to be empire blue not battle grey, but seeing as she started it that colour ,after i finished my tea i did all the rest, all the panels are also hanging and drying will take some more pics tommorow of my skills just look at that stright line ,and she did it all the way around ,up to the sump gasket "flipping auwsome
but for now leave it at my eldests tallents
little to deep with the brush in paint "must point this out to her in the future lol
heres the cowlings hanging and drying yesterday and any good weather since sunday see the original square of paint good match me thinks
wont be seen as id plate goes there ,but good for one of the next owners to find when they deside its time for a repaint,also on rear of id plate ive put restored august 2013 by me ect ect
cracked on again today as the topcoat covered in one go
and did the head in h/t silver as always
and then started to rebuild this late afternoon
not many parts left to go now carb,tank pipe,magneto,and these few bits and bobs then its wood work then crrank up
What paint do you use Kev you always seem to have a high class finish. Either its the paint or your daughters painting
ian
ian
Ibonaol- Expert
http://www.masonct.de/masonct/en-gb/SiteCollectionDocuments/1KTC_0PT%20Mason_%20P_%20Type_%201K_%20Topcoat_UK_Eng.pdfIbonaol wrote:What paint do you use Kev you always seem to have a high class finish. Either its the paint or your daughters painting
ian
i love the stuff
well this is what its looking like in the semi sun today as from were it was upto last night
well done the magneto timing and new ht lead and plug cap
fitted the carb and coke catch lever ,final polish of the pipe i made last week
fitted the small magneto acess side cowling
then discovered i reconed the wrong fuel tap, so did the right one with a hone polish and new cork fitted
and the pull start pulley and oil cap are drying in the shed ,
then its almost finished
looks really good in the Blue!
cheers lewis
its bloody close to the colour it was first coated with
well the old girl is painted, detailed timed ,changed the fuel pipe design "looks more clean this way
also made and then mounted on wooden frame work
just waiting on posty to bring me 2x tank bands new old stock ones
then its fuel up ,and find out if it is running as it should be again
oh yeah , i found this in the shed on clearing away the junk off my bench
so just a little more to do tomorrow if i can "twisted my knee and ankle "
the air filter is now finished other than a wing nut ,
remade the guvernor to carb linkage as was a few mm out ,to long "close but no cigar
made the throttle idioling lever out of brass ,just to add to the contrasts
had it running and i near poo"ed my pants as turned the fuel tap on ,pulled the choke lever out ,first pull and away it went
little slow weap from the brass union on carb from fuel pipe ,so added a fibre washer to see if that stops it
running a little rich but will be seeing to that as have a service kit for the zenith 24t2 series carb if needed
and made a stainless airfilter mounting bracket just to minimis the oilbaths shacking slipping around in use and spilling the oil out
so this it how it going to look as its all there and painted ,anything else i just tinkering for a smoother slower running engine
well its now on fleebay if anyone fancys one of my restored engines ,
http://www.ebay.co.uk/itm/villiers-mk-E30-4-stroke-stationary-engine-same-as-jap-4-3-bsa-not-lister-amanco-/330991775600?pt=UK_BOI_FarmingEquipment_RL&hash=item4d10a5af70
they has to go as needing the room for this winters projects
http://www.ebay.co.uk/itm/330991784543?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
and also the mark 10 "theVengine" war department 1945 early model
sadly they has to go ,as needing the room for this winters projects to arrive and survive in
well it went for a song on the flee exchange
and the same as the last 4 engines ,no rally fields for any of them ,this is 2nd going to a allotment rotavator
villiers diesel and jap twin 55 v/o saw benches
» Villiers 2-stroke
» 4 Stroke Allen scythe (Villiers MK25)
» villiers midget 2 stroke
» Villiers 11C Two Stroke rebuild
» Villiers mk15 4 stroke COIL???
