lister cs 6/1 startomatic lighting plant 2.5 kw
hi all just recovered a lighting plant from a farm on Exmoor in it great original condition as been in a barn all its working life protected from the weather .. I picked up engine last sunday and had it running mid day Monday and producing electricity... this model control box has a switch on side that you need to turn for engine to kick in a start and run.... how do I go about to set up so when a load is detected the unit will start and run... any held would be great many thanks dave ...
moonboots- I really need to post more
Re: lister cs 6/1 startomatic lighting plant 2.5 kw
Hi Dave, you can find the manual for the early unit here-
http://www.oldengine.org/members/diesel/ListerData/SOMMenu1.htm
It's off line at the moment but should return.
Mark.
Mark.
bottleveg- Posts : 3
hi mark thanks for the info will be a great help ...cheers dave
» Stuart Lighting Set
» Lister Startomatic decompression solenoid
» Delcolite lighting set.
» Lighting Display
» Lighting Display
