lister D blue smoke
lister D blue smoke
hi everyone
I have got a problem with my Lister d it has been running fine for ages until a couple of days ago when i started it up it started pouring white/blue smoke out of the exhaust which quickly filled the entire area. does anone know what is wrong because i have only been doing this a short while and have no idea.
tim
tim
tim white- I really need to post more
Re: lister D blue smoke
Just a thought Tim. Is there too much oil in it? otherewise could be worn piston rings maybe.
spit-bang- Expert
i checked the oil in it i think it is at the right level so it mustbe the piston rings have gone. thanks spit-bang
tim
tim
Could be the rings have got stuck in their grooves. Standing w/o being started for years or lots of cold running can do that.
I currently have two engines with that problem, anyone found a good way to unstick them, w/o stripping the pistons out and cleaning the grooves?.
Darryl Ovens- Expert
have you oiled the valves? i did that and because they have no valve seals the oil seeps through. the bore could be glazed. my bore was also glazed, after a quick hone and two rallies the smoke has cleared.
as for unsticking without removing the piston rings you can soak in paraffin or similar for a week or so, then using a brass wire brush give them a good clean.
hope this helps,
callum
hope this helps,
callum
» Lister D smoke
» Compression
» my new project for the winter
» Hopper cooling systems
» blue petter A
» Compression
» blue petter A
