strange problem with big end Villiers Mk15
Dear Forum members,
Last weekend I've experienced a weird problem.
After a short run I heard a knocking sound and stopped immediately.
After dismantling the oil sump I've seen that the big end cap had a play of several millimeters.
The locking pins in both nuts were still there.
Thank god there is no serious damage yet.
Has someone had the same experience before?
I have still no idea how this could happen.
Please let me know your thoughts.
Best regards,
Steef Pronk
Best regards,
Steef Pronk
Re: strange problem with big end Villiers Mk15
Just wondered could the heads of the bolts have not been right hard up against the shoulders? I assume these are "fitted bolts" that hold the cap on. Ie perhaps the corners of the hex on the head were against the side of the "rod" and running forces have allowed them to turn slightly so they slide right up to the shoulder allowing it to be loose. I've had bolts get pushed back slightly while pushing the cap, on then rotate to jam against the side while screwing the nut on.
Darryl Ovens- Expert
answer on strange problem
Dear Darryl,
Thanks a lot for your prompt reply.
I will check the bolts again.
Will let you know my findings.
Best regards,
Steef Pronk
Best regards,
Steef Pronk
» which RPM Villiers Mk15?
» new toy .......Villiers Mk15
» Dutch Villiers Mark 15
» Villiers mk15 4 stroke COIL???
» Villiers MK15 carb issue
