HELP! Lister D won't start.
Hi, I just restored a 1939 lister d. After some tinkering with the spark I mangaged to get it going (beautify well). After I turned it off to pack my tools away I tried to start it again and had no luck. I messed around with the carb but got no where. When Turing it over it seemed to be taking in air from a hole in the side of the carb and when I stopped, as soon as it hit compression the fly wheel bounced back and spat fuel out the same hole. Help please!
Sam Botham- I really need to post more
Re: HELP! Lister D won't start.
My first thought would be spark plug - fit either a brand new one or heat up the electrodes of the one you're using with a blowtorch and then put it back in hot and make sure the mixture wheel is fully open when you try to start.
My Lister D sometimes suffers from the same problem and the blowtorch cure usually works although I don't know what causes the plug to to foul She will happily run for for over an hour but then when I stop it she won't restart until I heat the plug (the electrodes glowing red) and then she will start again and run until I switch it off
Last edited by ray fisher on Mon Apr 04, 2016 6:09 pm; edited 1 time in total (Reason for editing : added 2nd paragraph)
ray fisher- Born to be wild
The spark plug is a new champion d-16 or I sometimes swap it for a new ngk equivelent. I will try the heating the electrodes, which is the end of the spark plug around the gap. Am I right?
You are correct
The plug I use is a champion - I tried NGK plugs and now have 3 all with less than 1 hrs runtime that now simply won't work in the Lister although they did when new. At least the the champion now has about 15hrs runtime.
I would love somebody to explain this problem in a manner I can understand because to me it just isn't logical and I have been working with internal combustion engines for 50+ years
» Petter PAZ 1 wont start
» lister d wont fire up :(
» Lister LR1 will not start after a catastrophe
» lister 2.5 kw start-o-matic not motoring up to speed
» Start o matic twin
