Norman t300 ongoing dismantle
Page 1 of 2
Page 1 of 2 • 1, 2
This is my first stationary engine project as normally motorcycles are my thing but prices are currently just plain bloody stupid. Anyway went to see a workmate showing his engine up at Newby Hall in the summer and saw these little beauties running so thought id give one a go. Bought from a lovely chap down south who bought it 20yrs ago in a bereavement sale and just sat it under his workbench for 20yrs. Sumps now flushed and barrels are now off, only thing found broken so far is a valve spring. Going to try and put pics on now wish me luck. Cheers Mark
Sparkieb- Expert
Sparkieb- Expert
Re: Norman t300 ongoing dismantle
Seven days before you post pics. Forummotion rules.
Sparkieb- Expert
https://i.servimg.com/u/f67/19/99/14/15/20180810.jpg
Mark yes I can be a touch grumpy
Sparkieb- Expert
https://servimg.com/view/19991415/9
Sparkieb- Expert
Tank, exhausts, Y-piece, air filter, and starting handle all present! You've dropped on a beauty!
Why isn't running?
Why isn't running?
I realised id dropped on a beauty when he sent me pictures
Sparkieb- Expert
Help !!!! Opinions and knowledge needed regarding Normans paint. Its not too bad but missing small areas, should i remove all the paint or just touch up missing areas. If its the original paint i really dont want to take it off. Do folk brush paint or spray ?
Sparkieb- Expert
Mine is a sort of Lister/Petter Brunswick Green - what little there is of it. I've seen them in all sorts of colours, depending on whether they were painted by Norman or the manufacturer who built the kit they were attached to.
My previous engines have been taken back to bare metal and spray primed and painted but they all had shrouds / fairings of some sort. With all the nooks and crannies on the T300 I think I'll brush paint in this instance.
Got a spray can and a small amount of paint in a tin today that colour matched oil filler top. Touched up a bit this afternoon, looks wrong but will wait until it dry's for final opinon. Found another green under topcoat that looks more military
Sparkieb- Expert
Sparkieb- Expert
Started stripping paint off 2 different greens underneath but base coat is possibly black or the darkest green ever seen. Dont know if i should use the green ive already bought but in my head im already saying no so might just bite the bullet and buy some correct very dark green, ohh and apparently i need an etch primer if i strip it back to bare metal.
Sparkieb- Expert
Sparkieb- Expert
Handy hint - use rags / paper towels or whatever to wrap around the pistons when you have the cylinders off.
Also, beware of opening up the crankcase. Apparently it's tricky and special tools are required.
If you whip off the governor cover you will find a small hole that leads into the oil gallery where you can blow through with compressed air after removing oil filter.
Sparkieb- Expert
Sparkieb- Expert
Ah - not going for an oily rag job then?
Found out that some engines left the Norman factory unpainted
Sparkieb- Expert
Sparkieb- Expert
Have used Lockside myself - very helpful.
BTW. What's the serial number on the sump - might be able to date it for you.
Mr Gallimore the Norman expert got in touch, its an early 1945 engine, other stamps on body are probably quality control he thinks. Hope to get a bit more done when grandaughters doors sorted
Sparkieb- Expert
Current update
Nothing to report on norman sadly as my wife decided our house needed freshening up
Sparkieb- Expert
Sparkieb- Expert
Page 1 of 2 • 1, 2
Page 1 of 2
