Norman t300 ongoing dismantle
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Norman t300 ongoing dismantle
Barrels are now on and tappets set, flywheel has been powder coated and ready to go on when my good friend chris has polished inner on his lathe for me. now for the bad news - took dip stick out to paint letters and noticed a small amount of oil on stick even though its been previously flushed and cleaned thoroughly, flushed again with petrol and removed some sludge from god knows where, repeated around 8 times until clearing but noticed some finings in flushed fuel/oil and on last flush some larger pieces. totally baffled as to where all this has come from as when the barrels were off I flushed/cleared thru repeatedly until it was spotless in both crankcase and sump. planning to move onto inlet manifold and carb next but feel a bit glum after finding these finings in previously spotless sump. Then its plug leads before finally the magneto which I hope is good (any info on magneto checking appreciated) . cheers Mark
will try and post barrels on pic again!
Mark yes I can be a touch grumpy
Sparkieb- Expert
This engine has a number of places where oil can hide, like in the bottom of the gear case, and in the oil pump and galleries. Did you also check the oil filter?
Yes flushed filter and housing quite a few times (engine had been stored 20yrs untouched) only thing i can thing of is i remover bearing cover behind flywheel and gave bearing a few squirts of oil, now wondering if it flushed debris down ?
Sparkieb- Expert
Sparkieb- Expert
Sparkieb- Expert
Sparkieb- Expert
Nice work, gives me an incentive to get cracking on mine. Just need to get the Villiers MK40 finished.
Magneto and carb next, ohh and plug leads. Needs some copper core cable
Sparkieb- Expert
If you fancy going completely over the top, you could go for screened leadsSparkieb wrote:Magneto and carb next, ohh and plug leads. Needs some copper core cable
https://picclick.co.uk/Screened-spark-plug-lead-magneto-lead-stationary-264250857516.html
not over the top at all, as this would seem to be original on the OP's engine
Sparkieb- Expert
That's what I did.
Sparkieb- Expert
Sparkieb- Expert
Sparkieb- Expert
Very tidy. Still jealous about the intact air filer and exhausts
Sheilded plug lead just turned up
Sparkieb- Expert
Sparkieb- Expert
What a carry on with the timing, lets just say lesson learnt.
Sparkieb- Expert
Not finished but wanted to make sure she's a runner
Sparkieb- Expert
Worked out slow running
https://youtu.be/yfttrzN_S6o
Sparkieb- Expert
Page 2 of 2 • 1, 2
Page 2 of 2
