Lister junior
Lister junior
Can you run equipment direct from the main flywheels
Albert1728- Born to be wild
Re: Lister junior
What are you planning on running? Sawbench will be too fast, same for a piston pump unless it's geared down on the pump, same with a gear pump, plate or roller mill again too fast...
Re: Lister junior
Hi Albert (?)
I took the liberty of moving your topic to a more (IMHO) appropriate section.
Best of luck with your project. Post some pictures when you get a chance.
Lister Junior
Woodsman wrote:Hi Albert (?)
Hi Paul,
I see you have moved this post, where to !!!.
Best Regards
Keith.
chiefy- A credit to the forum
Re: Lister junior
New Projects/Restorations
Lister Junior
Woodsman wrote:New Projects/Restorations
Thanks for that Paul.
Best Regards,
Keith.
