Villiers midget?
+5
Locknut
Keith-PU8
chiefy
donp
9 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Villiers midget?
Kev, This any good?
https://www.ebay.co.uk/itm/VILLIERS-MIDGET-STATIONARY-ENGINE-PARTS-See-other-listings-for-more/183837117237?hash=item2acd8bcb35:g:MBwAAOSwE4tc98B4
Hi blue cat,
Thank you very much for that - it certainly looks interesting.I will contact the seller and find out a bit more with a view to bidding on it.Its not to far from me either which is a bonus.
All the best,
Kev.
All the best,
Kev.
Have you repaired the crack in the cases with aluminium solder if you have the heat may have moved the bearing line up for the crankshaft, i would think with a crack like it has it would already be out of line prior to using heat to make a repair, because the crankcase is is a fuel mixer on this 2 stroke it is very important that the cases are gas tight .
Regards,
Chiefy.
Regards,
Chiefy.
chiefy- A credit to the forum
Hi Chiefy,
Thanks for your reply.
I have repaired the crack using aluminium solder and am quite pleased with that. I have slowly (to slowly!) come round to thinking that that half of the crank case when it was damaged was pushed out of line and so will need replacing.I am now looking for a midget mk1 crank case - I have seen several but none the same as mine.
Kev.
Kev.
Hi Locknut,
I have used the aluminium solder myself and it does a good job and i think you are correct in thinking the cracked crankcase means the bearings are out of alignment, hope you have good luck and are able to find a pair of replacement crankcases,ithink a pair is best.
Best Regards,
Keith.
Best Regards,
Keith.
Right Kev, third time lucky ???
https://www.ebay.co.uk/itm/VINTAGE-VILLIERS-2-STROKE-MIDGET-PETROL-STATIONARY-ENGINE-PROJECT/223565209866?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
You may have to persuade him to courier it though
Finding red rope starter plate that fits on flywhheel
Hello I’m trying to rebuild a 98cc ex greens mower Villiers engine but cannot locate a red rope starter plate that is shown on this engine that fits over flywheel nut any help please text 07341281685 many thanks Alan
VILL25- Posts : 1
VILL25 wrote:Hello I’m trying to rebuild a 98cc ex greens mower Villiers engine but cannot locate a red rope starter plate that is shown on this engine that fits over flywheel nut any help please text 07341281685 many thanks Alan
Hello and welcome to the forum.
You will probably have more luck posting in the 'wanted' section than tagging on to a 5 year old thread...
Also not a good idea to put personal contact details on an open forum, sadly there are scammers about.
Good luck!
Hi Alan and a warm welcome to the forum.
Sound advice from Matt.
Please take a minute to tell us a little about yourself / interests in New Members.
Page 2 of 2 • 1, 2
» Villiers midget Mk3
» Villiers Midget mk2
» Villiers midget modification
» villiers midget 2 stroke
» Villiers Midget engine
Page 2 of 2
