Corn mill that I need help with. Newbie alert
Re: Corn mill that I need help with. Newbie alert
You do not say what model it is but in general the smaller ones are more desirable due to their size. I restored a Rapid Grinding mill earlier this year it was a model 1C and was still a handful even on steerable castors due to the weight. Yours seems to be in good condition but I would take a look at the fixed and revolving grinding plates as if these are worn down it will not grind anything (check the back side of the two larger outer plates as these are reversible so may be OK on the other side). It has an incorrect sticker on the hopper and the sack hanger is missing. Also check the bronze bearings at either end of the drive shaft for up & down movement and check if the feed shaker mechanism is working OK.
After a full restoration mine sold for £550
The grinding plates should look like this:
Mine restored:
And grinding corn:
Mine restored:
And grinding corn:
Garak- Life Member
Oh fabulous. Thankyou so much matey
Carl Ray- Posts : 2
[quote="Garak"]You do not say what model it is but in general the smaller ones are more desirable due to their size. I restored a Rapid Grinding mill earlier this year it was a model 1C and was still a handful even on steerable castors due to the weight. Yours seems to be in good condition but I would take a look at the fixed and revolving grinding plates as if these are worn down it will not grind anything (check the back side of the two larger outer plates as these are reversible so may be OK on the other side). It has an incorrect sticker on the hopper and the sack hanger is missing. Also check the bronze bearings at either end of the drive shaft for up & down movement and check if the feed shaker mechanism is working OK.
I bought a Bamford no1 mill at a sale yesterday, so before I go any further I thought I better check the things you suggest. I have the cover off the grinding plates but am confronted with a large nut which I can't move on the shaft holding them together. Before I start using 'heavy persuasion' can you tell me is it a right or left hand thread please.
Philip
Philip
Philip
If I remember correctly it's a left hand thread
Garak- Life Member
Thanks, I'll try that
Philip
Philip
