Lighting board designs
Does anyone have any photos of their lighting boards used with generating sets? I want to get some ideas to make on up perhaps using LED technology that would make a nice display at shows.
Martyn
Martyn
Garak- Life Member
Re: Lighting board designs
This is one I made years ago, I think it looks better with the volts and amps showing, I mounted the lamps on the board, only ended up using it once or twice.
https://photos.app.goo.gl/TrBEWWemnTAyPaW28
Finished my two light boxes to show with my Stuart Turner generating set.
This one has two LED filament style lamps and a single LED star-burst style. The top two are 4w each and the bottom one is 1w. All three run @240v
This one is a tricolour LED cascade style decoration set, it draws 5w. These run @12v through a 240v - 12vdc power adaptor
Garak- Life Member
Hi Garak, the second board will certainly catch the eye of the spectators as they walk down the line.
Regards,
Chiefy.
Regards,
Chiefy.
chiefy- A credit to the forum
chiefy wrote:Hi Garak, the second board will certainly catch the eye of the spectators as they walk down the line.
Regards,
Chiefy.
I thought it would be different to show that old / vintge technology can be used with modern lighting technology . The second board was designed with kids in mind.
Garak- Life Member
» Light Board
» Delcolite lighting set.
» help with petter light contol board PLEASE
» lister cs 6/1 startomatic lighting plant 2.5 kw
» 12V LIGHT BOARD
» 12V LIGHT BOARD
