Petter A2 Magneto
Petter A2 Magneto
Petter A2 Magneto wanted wico A Must be reverse rotation with impulse
Kristoflines
Kristoflines
kristoflines- I really need to post more
Re: Petter A2 Magneto
Hi Kristoflines,
I took the liberty of moving you post the to appropriate section.
Hi Paul Thanks for your help This is all new to me but will get used to it eventually
Thanks again
Kristoflines
Thanks again
Kristoflines
No worries.
I have no info on A2. Do you know what type of Wico you need?
Wico magneto types for Petter air cooled engines are listed here:
http://www.oldengine.org/members/diesel/WipacMagneto/wipac2.htm
blue cat wrote:Wico magneto types for Petter air cooled engines are listed here:
Nice one 'blue cat'. I'd forgotten all about that site - now bookmarked.
Petter A2 Magneto
Woodsman wrote:No worries.
HI Woodman The A series engine that needs a mag is a Petter W1H No 577419R of 1951
Thanks Kristoflines.
Hi Woodman The A series engine that needs the mag is a Petter W1H No 577419R of 1951
Hi blue cat Thank you for that info now we know what I need, the next move is to try and locate one or find someone that can make up a suitable alternative from the mag that I have.
Kristoflines
Kristoflines
Hi Guys Just found an old Petter handbook for types A & W and states the mag as CJ 1219 but dont know what year that is for.
Kristoflines
Kristoflines
The Wipac CJ was the magneto which replaced the Wico A Series magnetos.
Hi Blue Cat do you have any idea when Petter started using the C.J. mag to replace the "A" and if an "A" mag could be substituted for the C.J. I have spoken to Jim Perkins but he says that most of his info is from diesels but he did tell me it was from 1951 and it was one of only 2 made then. (L/H)
Thanks for any help Kristoflines
The Wico A and CJ are interchangeable, just need to find a good one of either, there is some on ebay
Hi Villiers Thanks for your reply and help I will now start to look for the replacement, I hope the reverse rotation wont be too much of a problem.
Thanks again Kristoflines
» Wico Series A magneto types
» Petter A magneto
» Ptter PA2 twin cylinder magneto
» Petter A1 magneto
» Petter A1 magneto strip down
» Petter A magneto
» Petter A1 magneto
