Barr & Stroud sleeve valve engine
There isn't many Circa 1920 generator sets you can pick up and walk way with, this little Barr and Stroud is one of the few.
The set was made by Barr & Stroud, who where making use of their optics machinery shop post WW1 to produce the Burt-McCollum design sleeve valve engine on licence from Wallace circa 1918, who made the Glasglow sleeve valve stationary engine.
The engine was used for a lifeboat to from a spark gap Marconi radio set. .The 40cc single sleeve valve was designed to run at its rater 4000rpm from 20 minutes followed by 40 minutes listing on the receiver. The alternator produced 100v, 250W @ 800Hz
IMG_20190401_174443 by Stephen Williams, on Flickr
IMG_20190401_174724 by Stephen Williams, on Flickr
IMG_20190401_174746 by Stephen Williams, on Flickr
IMG_20190401_174952 by Stephen Williams, on Flickr
IMG_20190401_175000 by Stephen Williams, on Flickr
Since the photos it has had the correct magneto fitted.
Barr and Stroud Sleeve Valve Engine by Bryntin Photography, on Flickr
Cheers, Steve
Cheers, Steve
» Ruston & Hornsby 6VQ coupled to a Broom & Wade sleeve valve compressor
» LISTER A 1926 cage valve engine
