Norman T300 MK1 I.D. plate
Has any forum member an I. D. plate that goes on the top of the governor housing of a T300 MK1 that they would like to part with, or I have a good condition MK2 T300 plate and will be willing to do a swap, but before anyone asks I do not want to sell it. PM me please. T I A
donp- A credit to the forum
Re: Norman T300 MK1 I.D. plate
You could try Phillip Gallimore to see if he has any left. Not sure if he's on here but has recently joined facebook.
EDIT; Just seen you need MK1 - if he does have any they will most likely be late (Uxbridge) MK2.
nickh- Expert
Would swap but unfortunately mine is an ALCO plate .
Good luck in your search.
The Norman T300 Mk1 id plate is usually an aluminium casting, but can be replaced easily and simply with a piece of 1/4 inch aluminium plate, shaped to fit, holes drilled, and the number stamped on the top surface. For the perfectionist it can be distressed with a few knocks, dints scrapes and cuts. Nice easy job for a wet weekend like this one.
Thanks for that info. Blue Cat, I think I have a piece of alloy plate in my garage somewhere, so as you say on a weekend like this one is forecast to be, thick coat, hat 2 pairs of socks on my feet and something to stop garage door from rattling might be my tomorrow sorted. L O L
T300 I. D. engine plate
Success, found a piece of alloy plate in my bits and pieces box, that you always say " that might come in handy one day" well I do anyway, made a plate up to day and it looks like blue cat says it should look complete with dings and scars, so the T300 MK 2 plate is now not needed anyone need one?, this is what is on it, TYPE T. 300 then in the diamond shape NORMAN underneath WARWICK ENGLAND ENGINE N0 TA 4013
Can photo it if you PM me an email address to send photo to, make me a sensible offer can easily be posted.
