Villiers MK20
+10
dunitrong
Robotstar5
Alanengine
StuartTurnerSteve
donp
mattblack
14 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Villiers MK20
Woodsman wrote:Re Bakelite ferule: I had a similar problem, some numpty has use Loctite on the threads.
Once you have the backplate off try acetone or superglue solvent from the inside. Soak overnight then some gentle heat - Rinse and repeat.
If there is no evidence of Loctite then substitute Plus Gas for solvent. With patience it should come out eventually.
If you bust it you may get a kit
HERE
but check diameter first.
Too late...
I think it was just corrosion of the the ali backplate with mine
Re: Villiers MK20
That's seen a bit of moisture!
Re: Villiers MK20
Looks to me like valve is beyond repair - by the time you have cleaned it up the edge will be paper thin. Try L&S.
Valve seats should be OK if you can find a suitable cutter.
I dropped on a Sykes Pickavant set after much trawling of 'tinterweb
Re: Villiers MK20
New valve shouldn't be a problem.
I've been looking at seat cutter sets on ebay/Amazon, the cheaper one all seem to come from India and the reviews are shall we say 'mixed'...
Re: Villiers MK20
New valve here for £4.
https://www.ebay.co.uk/itm/Villiers-MK20-Mk25-Exhaust-Valve-Genuine-Original-Villiers-Part-EM393/124230075570?hash=item1cecb084b2:g:cjgAAOSw5KBckWuA
https://www.ebay.co.uk/itm/Villiers-MK20-Mk25-Inlet-Valve-Genuine-Original-Villiers-Part-EM116/124230075729?hash=item1cecb08551:g:cjgAAOSw5KBckWuA
Re: Villiers MK20
Thanks to a suggestion on another forum I called a mower repair shop and if the chap can lay hands on his old imperial cutters he recons he can sort it out so hopefully the project can continue.
Re: Villiers MK20
If he finds them - make him an offer!
You could also look for local vintage car/motorbike restorer.
Re: Villiers MK20
Great work, cleaning up well. Rugged little engines, I'm working on a 25hs at the moment- I think they are the same other than the bore?
I found the cowling the worst part to clean up, good luck with yours.
Alan
Alan
Re: Villiers MK20
My £20 Indian valve seat cutters arrived earlier this week...
...and made short work of the pitted exhaust valve seat. I also gave the inlet seat a light cut and ground the valve in. I will now order a new exhaust
valve.
Other than that, I have just cleaned the mag backplate up and made a start cleaning up the head.
valve.
Re: Villiers MK20
Great bit of kit, doesn't look like you had to take too much out, at least you know you will have a decent deal.
How do they make it for £20! unbelievable, you could hire it out!
Alan
Alan
Re: Villiers MK20
Alanengine wrote:Great bit of kit, doesn't look like you had to take too much out, at least you know you will have a decent deal.
Alan
They are actually listed on ebay for £24.99 IIRC but with 'make an offer' so I possibly could have got it even cheaper. It was very well packed, but the tin is comically crude. Looks like it was hand made, and it has the thumbprint of the bloke who painted it (with a brush) inside the lid.
But I'm not complaining!
Re: Villiers MK20
mattblack wrote:They are actually listed on ebay for £24.99 IIRC but with 'make an offer' so I possibly could have got it even cheaper. It was very well packed, but the tin is comically crude. Looks like it was hand made, and it has the thumbprint of the bloke who painted it (with a brush) inside the lid.
Do you have a link or item number please.
Re: Villiers MK20
https://www.ebay.co.uk/itm/VALVE-SEAT-CUTTER-SET-5-CUTTER-CARBON-STEEL-SET-FOR-VINTAGE-CAR-BIKES/293139180170?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Re: Villiers MK20
Done a bit more...
New exhaust valve ground in, cylinder cleaned up and painted.
Magneto reassembled.
Head cleaned up.
Pretty much ready to get the main bits reassembled now, then on to tackle the carb.
Incidentally, does anyone know the reason why Villers decided to earth the moving contact of the points rather than the fixed one? That's the opposite to all the car points I've ever come across.
Head cleaned up.
Re: Villiers MK20
Coming on nicely! Have you honed the bore, looks fresh?
Alan
Alan
Re: Villiers MK20
Alanengine wrote:Coming on nicely! Have you honed the bore, looks fresh?
Alan
Kind of, I haven't got a honing tool so as advised on another forum I run an 80 grit flap wheel quickly up and down the bore to de-glaze it.
Re: Villiers MK20
Had quite a productive weekend on this. Magneto and new sump on:
Flywheel/fan cleaned up:
The rather battered cover, it's made of very thin ali but I managed to get the worst of the dents out, I'm calling rest patina...
Flywheel back on, points and timing set (twice, as the first time I set it 3/16" after TDC...) rigged up an HT lead and WE HAVE SPARKS!
So head on and that's where we're at. Carb next.
Re: Villiers MK20
Looking good
Weren't you tempted even a little bit to squirt some fuel down the plug hole and give it a pull?
Re: Villiers MK20
Robotstar5 wrote:Looking good
It honestly never occurred to me... it would have set next door's dogs off a treat though.
Re: Villiers MK20
Started on the carb today.
Biggest problem was the throttle spindle. It was seized and when I thought I had freed it off it was in fact still seized in one side so it twisted. I then did what I should have done from the start and applied some heat and it came out.
I have straightened it out but I will look for a replacement.
Float bowl needs a good clean out.
Stripped and cleaned up.
Carb body after a tickle with the whizzy wheel.
Re: Villiers MK20
Now that's looking better!
Alan
Alan
Re: Villiers MK20
I am getting like the owner. Can't wait to hear it run again.
Many Thanks
Andrew
Many Thanks
Andrew
» Villiers MK20 HS
» Villiers Mk20 before and after
» Villiers MK20 - yes another one !
» Silencing Villiers MK20/25
» Villiers MK20 with Reduction box
Page 2 of 4
