Villiers MK20
+10
dunitrong
Robotstar5
Alanengine
StuartTurnerSteve
donp
mattblack
14 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Villiers MK20
Re: Villiers MK20
Brilliant!
Dragon's Den awaits...
Re: Villiers MK20
I like that! Must show
it to wife she has a wood lath.
dunitrong- Expert
Re: Villiers MK20
https://www.ebay.co.uk/itm/villiers-mk-25-engine-exhaust-silencer/333893151075?hash=item4dbd952963:g:BPcAAOSwWDBgFw32
Re: Villiers MK20
paul,
You could spin a new one with that wooden pattern.
Re: Villiers MK20
maryalice wrote:paul,
Tried a while ago and failed but maybe I'll give it another go.
Re: Villiers MK20
There are a couple of books on the subject, I've made the ends for my Lister fuel tanks on my lathe using emersion tank copper.
Re: Villiers MK20
maryalice wrote:There are a couple of books on the subject, I've made the ends for my Lister fuel tanks on my lathe using emersion tank copper.
I've seen them spinning the ends of immersion tanks, looks quite frightening to see a 2 foot copper disc spinning at a few hundred rpm held in place by friction.
Re: Villiers MK20
Its not that bad, as long as you keep to one side of the chuck, my lathe isnt that big but I can spin a 12" disc, my tool is about a foot long with a radiused end.
Re: Villiers MK20
maryalice wrote:Its not that bad, as long as you keep to one side of the chuck, my lathe isnt that big but I can spin a 12" disc, my tool is about a foot long with a radiused end.
I think there are specialist groups/forums for that sort of thing
Re: Villiers MK20
Nice to see you are coming up to the same level of Appletop, or is it down
Re: Villiers MK20
[quote="Robotstar5"][quote="maryalice"]Its not that bad, as long as you keep to one side of the chuck, my lathe isnt that big but I can spin a 12" disc, [b]my tool is about a foot long with a radiused end.[/b]
Maryalice[/quote]
I think there are specialist groups/forums for that sort of thing [/quote]
Maryalice[/quote]
Re: Villiers MK20
I'd heard the term but didn't really understand the idea until I saw a bloke spinning a vintage headlight shell on a TV program. Amazing to watch.
Re: Villiers MK20
Andrew1971 wrote:I am getting like the owner. Can't wait to hear it run again.
Many Thanks
Andrew
No pressure then...!
Just a quick update from the weekend.
Carb back together as far as I can, new throttle spindle and float bowl seal ordered.
Float bowl cleaned up and given a quick coat of Hammerite.
Air filter was bent and the choke was seized so I thought I may as well have a go at splitting it, I managed to bend the folded over edge of the front enough to get it off. I've got a plan to re-assemble it.
Re: Villiers MK20
I made a bridge piece, welded a captive nut in the middle and soldered it into the air filter body and drilled the cover for a screw.
Had this C12 exhaust, the end was rusted away so I cut the elbow off, made 2 cuts in the remains of the threaded part and collapsed it to remove it.
The new silencer screwed in, although I wonder if being for a Briggs & Stratton it is actually American NPT rather than BSP?
I re-drilled the flange on the original elbow to bring the exhaust vertical.
All cleaned up, painted and fitted.
Turned my attention to the fuel tank, not the best photos but I was pleasantly surprised by the condition of the inside, certainly no worse than the others I've done.
With a bit of heat I was able to save all the tank strap fittings
Re: Villiers MK20
You've got to be resourceful sometimes! The exhaust looks the part, I'm sure I used one like that on a Suffolk engine.
Coming along nicely.
Alan
Alan
Re: Villiers MK20
Nice work Matt - nearly there!
Re: Villiers MK20
An interesting piece of re-engineering. Certainly looking good and should produce a fine example when finished, which doesn't look that far away. Hope you have it running soon.
Neil.
Neil.
Re: Villiers MK20
Not much to report. Tank brackets cleaned up, primed and painted gloss black. I used Wilcos own brand gloss black aerosol, I used their paint on my MK15 and find it covers well and is cheaper than others. On closer inspection a couple of the screws were past their best, one was bent and one had a dodgy thread. I had a couple of spares from a C12, the heads are shallower (probably cost reduction on the later engines) but they will do the job.
Re: Villiers MK20
Progress is progress! Your doing a thorough job there, should turn out well!
Alan
Alan
Re: Villiers MK20
Alanengine wrote:Progress is progress!
Alan
True. I'm pacing myself a bit, just doing a bit at weekends. Now the weather is warming up and the evenings are lighter there are things to do in the garden (although that's mainly the O/Hs domain) and of course hopefully we will soon be able to get out and about again. I also seem to have somehow talked myself into a bathroom renovation project...
Re: Villiers MK20
A (little) more progress...
Bit the bullet and started on the tank, did the usual handful of nuts and bolts and paraffin thing to clean it out then set to with the wire wheel in the drill followed by 80 grit paper.
Then a coat of 'Johnstones' brushing red oxide.
I'm still undecided whether to give it another coat and then flat it, TBH I'm not standing too proud over the finish. I could spend ages with stopper ect getting rid of all the pitting but I think it's part of it's character (that's my excuse anyway... )
Re: Villiers MK20
Coming along nicely, especially when looking at the pictures above, of the state of the tank before your efforts! I agree with you, a bit of natural character can look so much better on an older engine, than an absolutely pristine finish. You'll soon have it completed and up and running, ready to show. I think you'll beat me to it.
Neil.
Neil.
Re: Villiers MK20
Why spend hours making it look like something it wasnt, it would never have left the factory looking pristine, the paint would be adequate and the castings would have been slightly better than rough. The engines were built to do a job not look pretty, even high end cars, if you look closely, have not so near visually perfect engines, they are hidden so dont need it.
Re: Villiers MK20
I think you have to draw a line when it comes to refinishing. Painted rust pits look like what they are, but lightly disguised, although still apparent can look better and more appropriate than a silky smooth glass like finish.
Alan
Alan
» Villiers MK20 HS
» Villiers Mk20 before and after
» Villiers MK20 - yes another one !
» Silencing Villiers MK20/25
» Villiers MK20 with Reduction box
Page 3 of 4
