Petter A1 Starting Issues
+7
maryalice
oldgit
Stu Pashley
Gaudin98
Robotstar5
tony RA
11 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Petter A1 Starting Issues
StuartTurnerSteve wrote:The impulse coupling retards the spark until just after the piston passes top dead centre for starting, so should be opening as the impulse clicks.
15k ohms sounds high, 3-7KOhms is what I tend to look for. Pull the suppressor cap off.
Thanks have cut suppressor off and is now own to 5 K Ohm's so will make a new HT lead up.
Stu Pashley- Born to be wild
Thanks have cut suppressor off and is now own to 5 K Ohm's so will make a new HT lead up.maryalice wrote:As told by my magneto repairer, Bin the suppressor they bugger magneto's.
Did you check this out.Stu Pashley wrote:Would that not mean it would then be firing at BDC rather than TDC. If I turn it over it fires at TDC put points seem to close before impulse rather than openingGaudin98 wrote:The mag is fitted 180 degrees out.
Gaudin98 is suggesting that the magneto rotor is 180 degrees out.
This would would make it 360 crank degrees out; causing the spark to occur at the, end of exhaust/start of induction stroke, rather than end of compression stroke.
if this is the case; your engine will not start, no matter how good your spark is.
Re oldgit's post.
Why not just whip the head off and watch the valves cycle ?
That sounds good.
Or take the plug out and maybe you will be able to see the valves.
Or, press your thumb on the plughole and you will be able to identify the compression stroke by feel as you turn the crankshaft.
Got there before me oldgit Note to self - THINK before posting.
Should be able to feel the compression as you turn it over. Thumb over spark plug hole will indicate if there is some compression but not enough - should get a little burp just before impulse trips.
Just had a duh moment.
My A1 had a decompression lever fitted so you could crank like billy-o to get it spinning then let go of the lever to get compression.
Stuart please confirm either way.
[quote="Woodsman"]Just had a duh moment.
Stuart please confirm either way.[/quote]
Oh no you don't!!!! The Petter A1 has an impulse on the magneto and you should only need to pull it smartly over compression and not "swing it like billy-o". All the decompression lever is for it to allow you to turn the engine over for service use and is not a starting aid.
Did they make a diesel version of this engine?
I only ask as it seems an extravagance to have a de-compression system on a spark ignition engine.
My Lister L had a decompressor on it as standard as does my Lister M, without it they are pigs to get going let alone start, its not uncommon.
[quote="oldgit"]Did they make a diesel version of this engine?
I only ask as it seems an extravagance to have a de-compression system on a spark ignition engine.[/quote]
Yes, the PAZ1. Same base bolt holes but most of the rest is different.
Or the AA1.
Some Petter A1s had compressors, on the valve chest IIRC.
My little Condor has a decompressor, still the engine will stop you dead if you don't catch it right.
Presumably during a 'brain failure' I remember picking an A1 up a few years ago for £20 and it had been 'rebuilt' by somebody in the past but they never got it running so they sold it at a farm sale and I got it from the lad who bought it just for the mag but then decided to sell it complete. The rebuilder had obviously tried hard as the plug threads were stripped where he had it out that many times, I recut them to 18mm. However to get back on track: the magneto was 180 degrees out, the throttle linkage was upside down so it was permanenty closed and on investigation it had new rings fitted but the con-rod was the wrong way round, other than that he had made quite a good job of it! It ran quite well eventually, but as I didn't rally it much I sold it on.
So firstly thanks for all your advice so far it is much appreciated. Well today I made some progress. Checked Magneto and think it was 180 degrees out as suggested so now set to fire at 20 degrees before TDC on compression. Cleaned and checked points set to 15 thou. New HT lead fitted(with out suppressor!!). Then gave it a try again. Managed to get it to run a few times for no more than 30 seconds before it died(note need to find and exhaust as it's seriously noisy with out one!!). Loads of fuel leaking from the bottom of the carb where the small bronze coloured plug is. Carb is set at Mixture 2 1/2 turns out, Air Reg 3/4 turn out and slow running jet 2 turns out. Tried adjusting settings but still wouldn't run for more than 30 seconds( I have stripped and cleaned carb again and checked float is Ok(also has a new needle valve and slow running jet fitted). Any ideas anyone?
Thanks maryalice, my experience of stationary engines is somewhat limited, also my experience of magnetos the same.maryalice wrote:My Lister L had a decompressor on it as standard as does my Lister M, without it they are pigs to get going let alone start, its not uncommon.
Due to one of these posts I now see the reason for the impulse mechanism.
As a matter of interest were the Lister L and Lister M fitted with non-impulse mags?
I did once (some years ago) pick up a book on Lucas magnetos, which I was reading in a slack period at work. An engineer saw it and said he'd like to read it as he was having trouble with his vintage motorcycle magneto, so I put a book mark in and said don't lose my page and handed it to him; that's the last time I saw that book.
The Lister L had no impulse mechanism fitted and just to muddy the waters a little the M has a none rotary magneto called a Flick magneto which is effectively an impulse magneto but it doesnt rotate.
[quote="maryalice"]The Lister L had no impulse mechanism fitted and just to muddy the waters a little the M has a none rotary magneto called a Flick magneto which is effectively an impulse magneto but it doesnt rotate.
Maryalice [/quote]
To really muddy the waters the Wico EK has even less moving parts, only the points carrier moves on them.
Maryalice [/quote]
Forgot that one.
So firstly thanks for all your advice so far it is much appreciated. Well today I made some progress. Checked Magneto and think it was 180 degrees out as suggested so now set to fire at 20 degrees before TDC on compression. Cleaned and checked points set to 15 thou. New HT lead fitted(with out suppressor!!). Then gave it a try again. Managed to get it to run a few times for no more than 30 seconds before it died(note need to find and exhaust as it's seriously noisy with out one!!). Loads of fuel leaking from the bottom of the carb where the small bronze coloured porous plug is. Carb is set at Mixture 2 1/2 turns out, Air Reg 3/4 turn out and slow running jet 2 turns out. Tried adjusting settings but still wouldn't run for more than 30 seconds( I have stripped and cleaned carb again and checked float is Ok(also has a new needle valve and slow running jet fitted). Any ideas anyone?
Is the float height adjustable?
mattblack wrote:Is the float height adjustable?
No can't adjust the height of the float. Can put a washer under the needle valve to lower slightly which I have done already(1mm). Float seems fine not leaking and seems to float on the bench no problem.
Try running the engine with the fuel cap off the tank, the air bleed maybe blocked stopping the fuel to flow.
Got there before me Maryalice.
But if it runs for 30 seconds it seems ignition side is close.
[quote="Woodsman"][quote="Appletop"]
Oh no you don't!!!! The Petter A1 has an impulse on the magneto and you should only need to pull it smartly over compression and not "swing it like billy-o". All the decompression lever is for it to allow you to turn the engine over for service use and is not a starting aid.[/quote]
[url=https://servimg.com/view/19972956/138][img]https://i.servimg.com/u/f31/19/97/29/56/starti10.jpg[/img][/url][/quote]
Fair enough, never used one that way, always just snapped mine over.
Was always told cranking an impulse weakened the spring.
» Petter A1 or is it A5 (starting issues and no serial no)
» Amanco Hired man starting issues
» Petter A Series II - Wico A Magneto Issues
» Petter PA2 - 'not starting'
» Petter AD1 not starting....
Page 2 of 3
