Solex carb
Solex carb
Solex carb for a Bamford EG1 required, cash waiting
Frenner2011- Born to be wild
Re: Solex carb
Have some info on which config' was used on EG1 but I seem to remember someone running an EG1 with a Lister D carb' which might be easier to get your hands on. No doubt someone will correct me if I'm wrong.
Re: Solex carb
I have heard of that conversion, would mind giving that a try if anyone has any info on it?
Re: Solex carb
You will just need to make a conversion adapter plate as the Bamford inlet has a horizontal flange and the Lister D carb has a vertical flange. Use something like 1/4 inch plate, iron, brass or ally for this.
Re: Solex carb
I did think of that, its also getting the governor linked up without looking a bit heath Robinson... still, its a project!blue cat wrote:You will just need to make a conversion adapter plate as the Bamford inlet has a horizontal flange and the Lister D carb has a vertical flange. Use something like 1/4 inch plate, iron, brass or ally for this.
Re: Solex carb
chuffchuff wrote:I have a Solex Carb that I think came off of a Douglas flat twin not sure if it would be any good for your project?
I believe EG engines were fitted with A Solex 26FH but cannot see model number on photo's.
Re: Solex carb
Thanks for the offer, but I've now found a replacement carb, the resto is on!!
Re: Solex carb
Excellent. Onwards and upwards.
Re: Solex carb
Good stuff that you've found a carb. It may be a matter of interest to some that the one I have is a 26FHG. good luck with the restoration.
Re: Solex carb
chuffchuff wrote:Good stuff that you've found a carb. It may be a matter of interest to some that the one I have is a 26FHG. good luck with the restoration.
As fitted to Norman T300 - thought I recognised it.
» Solex carb
» Solex Carburettor
» SOLEX FH Carburettor information
» Solex 26 FH Carburettor
» Solex 26 FV on Coborn C3
» Solex Carburettor
