Lister D Restoration ~1928/29 shaft drive with Ricardo head
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Lister D Restoration ~1928/29 shaft drive with Ricardo head
I ended up cracking the filler cap flange slightly but it's a very thin hairline crack and hasn't gone all the way through so should be fine. Soldering went ok and a pressure test in our water butt
indicates no leaks. Overall happy with the way it turned out. Just waiting for the first coat of paint to dry.
petermwilliamson- Born to be wild
Tank now painted and fitted. I do however have some questions on the setup of the early float-less models. I have Carb D65 which as far as I can tell is correct for spec 11D2. However the jet (1/780) doesn't have the correct thread to couple with the 5/16" BSP fuel pipe. Did the 11D2 engine have a different Jet or is there something that sits in between them?
I've found this photo which suggests the former:
This is what mine looks like:
My second question is about something I read; Should a non-return valve be fitted?
Today is finally the day where I can say she’s complete. The tank finished, painted and fuel-tight a few months back, the only remaining item on the to-do list was the connection to the carb. I couldn’t find any information so have come to the conclusion the jet is different on the early models, these being a male threaded. A union was needed.
9/16 BSF 16tpi one end and ΒΌ” BSP 19tpi the other along with a 60 deg chamfer. A couple of hours work on the new lathe (yes, I finally have one!) and bang, done.
First start-up in the final “float-less” setup was today. The first try was not great, it would either run way too fast and walk itself across the garden or die with the mixture leaned out. A bit of an anticlimax but at least it ran. A cup of tea later and I noticed the throttle spring had gone slack again and was not doing its job. A few turns later and she was running fine.
I've never had an issue connecting the pipe to the carb, I will check a couple to see what the fitting is on them, after you've run it for a long period you will find that you will have to open the fuel valve a little as the head of fuel drops in the tank, tighten the spring in the carburettor a little and it will run a bit more even.
Nice tank by the way.
Thanks, if you have a photo of the bottom of a carb for this model/year that would be interesting. Looking at the photo in the post previous to mine, the jets look quite different. Either way, my diy union seems to do the job. I did fear there needs to be a non-return valve in there but it seams not.
TBH I think the throttle spring has seen better days and will probably need replacing soon, I've almost run out of adjustment. I'm super happy though and will give it a longer run soon. I did read a while back about having to tweak the mixture as the tank level drops, quite logical. The tank turned out much better than I expected, thanks to your help I'll add! Having a look at yours was very useful.
Thanks Stuart. They look to have done the same as me.
Page 2 of 2 • 1, 2
» 1928 low tank shafty restoration
» Lister D shaft drive - my new / first project
» My lister D type shaft drive.
» Lister D shaft drive magneto timing
» Ricardo head broken stud repair/removal.
Page 2 of 2
