Lister D oil filler cap
The oil filler cap on my Lister D leaks oil, there appears to be no seal on it, should there be, or is there another cure to try please.
John Wilkins- I really need to post more
Re: Lister D oil filler cap
It's normally a ground metal to metal seal, and should only be filled until the oil is level with the filler (with the engine on a level surface), so check you don't have excess oil in the sump. However, there is no harm in fitting a thin cork seal if there is a persistent leak, it will hardly be visible once in place.
Thanks for your reply, I think a cork gasket will be in order, the level is bang on, but when moving the engine around is when it dribbles a bit.
Many thanks
John
Many thanks
John
» My new toy my jap 2a
» J.A.P. 5 Filler cap problem
» Looking for space filler
» Coventry Victor AD2/3 Oil filler cap / dipstick
» Lister A help (again)
