Vire 6 BVK engine
Vire 6 BVK engine
Need to replace the damaged cylinder on BVK engine. Also need to replace the clutch lever (been cutoff) Thks Des
Softy42- Posts : 1
Re: Vire 6 BVK engine
Hi and welcome to the forum.
I took the liberty of moving your post to a more appropriate section.
I guess you've no luck with Vire Engines in Bournemouth?
» Anyone know about Vire Marine engines???
» Can anyone confirm this engine is a Keighley Engineering gas engine?
» Gaskets for a JAP 3 OHV engine NOT A SIDEVALVE ENGINE
