building a exhaust pipe
hi , i need to make an exhaust soon for my duetz as i could end up starting some fires as the exhaust blows down wards , and sparks which could lead to dried grass catching in the summer, does anyone no what the shortest angled pipe i can get i think its the same sized thread as a D
Re: building a exhaust pipe
You can get a 90* elbow, this is about 1 1/2 inch to the bottom after you have screwed it in. Get a black iron one not a galvernized one.
Do you know were i can get x2 from and how much rougly its defo gonna be black
Should get change from a fiver. You need to ask for a 1inch male x female equal elbow
as villiers says ryan, get elbows with a male end and female end, that way if you get bored............. no sorry wrong idea, erm yeah, anyway moving on................. malleable iron is the cheapest (black iron) but the forged ones made from steel can be welded.
lister D's are 1" British Standard Pipe, BSP, measured from the inside diameter of the bore
Does anyone know were i can get piping to
good plumbers merchants, or steel suppliers, though the latter will be more expensive lol
You can buy exhausts from the plumbers , really, ill get down there monday didnt realise that
S.J. Andrews in Redruth sells black iron pipe fittings - they've always seemed cheap for those... just make sure it's the black iron ones you select or your wallet will take a battering!!!
Can't beat a good crank - I have one every day...
Hope and Crank- A credit to the forum
Do they thread it for you? its just i dont wanna go in there and make a tit out of myself as they have ripped me off twice recently
These should be pre-threaded. You're right, they are expensive for some stuff, we had about 150kgs of (10 inch?) channel from them last year and that cost an arm and a leg!!
If you don't want to make a tit of yourself or are unhappy with them, have a go online at :
These
If the wrong bit comes nobody is looking !
Ken
These
Ken
» Lister D exhaust pipe
» Ruston 6AP Exhaust Pipe + Oilers
» trolley building
» BSP pipe fittings ?
» Trolley Building
» trolley building
» Trolley Building
