Trolley Building
Trolley Building
Post by Gary.B on Wed Jul 03 2013, 20:32
Hey Guys,
I'm going to be attempting to build a new trolley for my Ruston PT over the next couple of weeks. Do you have any tips or points to be considered and maybe mistakes you've made in the past or things that should be avoided?
Thank you
Gary
I don't actually have a clue what I'm doing. Rolling Eyes
Gary.B
Re: Trolley Building
Post by matt86 on Wed Jul 03 2013, 20:35
Gary.B wrote:Hey Guys,
Thank you
Gary
building out of wood or steel ?
Post by Gary.B on Wed Jul 03 2013, 20:50
Sorry, I have some 70mm x 70mm hardwood.
Thanks.
Gary.B
Post by matt86 on Wed Jul 03 2013, 21:03
Gary.B wrote:Sorry, I have some 70mm x 70mm hardwood.
Thanks.
great start hardwood , soft wood is useless for joining ....
Make sure you mark your joints tight and cut your outer cuts and sevral inbetween so when you chisel smaller chips come out rather than bigger ones causing too much to be removed.... thats if you are joining it as you could use coach bolts and coach screws ....
Post by Abes on Wed Jul 03 2013, 21:31
Here's one I made for the Wolseley am using the same sort of design for my PT, flywheel will be positioned off the side, only words of advice is measure twice cut once lol
Post by kevjhnsn on Thu Jul 04 2013, 00:47
dont bolt the cross members, in the way of the bolts for base holes for the engine:oops: Embarassed
Post by Gary.B on Thu Jul 04 2013, 15:15
Abes wrote:Here's one I made for the Wolseley am using the same sort of design for my PT, flywheel will be positioned off the side, only words of advice is measure twice cut once lol
Nice job, I was wondering whether it was necessary to offset the axles because of the weight of the flywheel off one side might make it unstable?
Gary.B
Post by Gary.B on Thu Jul 04 2013, 15:16
kevjhnsn wrote:dont bolt the cross members, in the way of the bolts for  base holes for the engine:oops: Embarassed
Yeah I'll bare that in mind.Smile
Gary.B
Post by Matth92 on Thu Jul 04 2013, 16:37
Here is my Ruston PT on its trolley that I made for it, only a very simple trolley but I think it looks the nuts
For that sort of size engine I always use 3x3 for the main bearers, and 2x3 for the crosspieces, putting a nice big chamfer on the ends of the crosspieces always looks nicer I think, I always try to find a set of 4 matching wheels when I can!
Post by matt86 on Thu Jul 04 2013, 17:30
Matth92 wrote:Here is my Ruston PT on its trolley that I made for it, only a very simple trolley but I think it looks the nuts
matt i wonder why all the prices of 3x3 fence posts have been going up !Laughing Laughing
Post by Gary.B on Thu Jul 04 2013, 17:33
Nice set up, I have 3 x 3 so that's sorted, how have you attached the axles? I've been searching for cast wheels, no luck so far.
Gary.B
Post by matt86 on Thu Jul 04 2013, 17:37
Gary.B wrote:Nice set up, I have 3 x 3 so that's sorted, how have you attached the axles? I've been searching for cast wheels, no luck so far.
i have got some up for grabs but your a tad far unless you dont mind paying for postage via courier ???
Post by Matth92 on Thu Jul 04 2013, 19:53
Nah Matt, the fat man gave me loads of bits of it last year! got a lifetime supply!
I usually make my axles out of solid round bar, and have 2 tabs welded on with 2 holes in each so you can bolt/coach screw the axles to the crosspieces, I usually just use coach screws these days cos Im lazy
Post by Gary.B on Thu Jul 04 2013, 21:02
Thanks Matt I'll try and get some locally, it cost about £70 to get a pallet sent up here. Shocked
Gary.B
Post by Matth92 on Thu Jul 04 2013, 21:17
Youll find some, 8 inch ones like mine look about the right scale for a PT, but they are quite hard to find!
Post by matt86 on Thu Jul 04 2013, 22:17
would not have to pallet them , box them up and use my hermes would be around 30 i think
Post by Gary.B on Sun Jul 07 2013, 07:49
Thanks Matt I'll bare that in mind, I've put the feelers out locally so hopefully I'll get something turn up soon. The wood is arriving on Thursday so I'll draw up some plans today and then crack straight on with it, need to get her out of that smoky garage. Smile
Gary
Gary.B
Post by chrismac on Mon Aug 12 2013, 21:29
Hows things, have you got the trolley made yet!!.
chrismac
I really need to post more
Post by Gary.B on Tue Aug 13 2013, 06:39
chrismac wrote:Hows things, have you got the trolley made yet!!.
Not yet Chris, I think I'll wait for the dark evenings to set in. Smile
Gary.B
