Petter A1 crank seal
Anyone recommend where to buy a crankshaft seal for an A1 please?
Chippie- Born to be wild
Re: Petter A1 crank seal
Hi Chippie,
If you can get the seal out without to much damage to it take it to somewhere like BSL, If theres numbers on the old seal they should be able to help you out.
Ive done that with bearings in the past.
Hope that helps.
Hope that helps.
Paul,
Thanks for the recommendation..I'll try not to damage it..
John
John
No probs John,
Ive had a look in the Petter manual but they dont have part numbers, Dam shame that may have helped you as well.
Best of luck
Best of luck
» petter a 1947 crank pin diametewr
» Lister ld1 oil seal
» Maytag 72 twin oil seal question
» Benco vacuumpump overhauling update 03072015 dating the pump. Yes it's very old!
» Crank case cleaning
