VILLIERS 4 STROKE MK 10 PRODUCTION PERIOD ???????????
Post by kevjhnsn on Fri Sep 16 2011, 00:59
do you know the production dates of villiers 10s and 12s
ive started to restore a villiers 10 with 2 small brass plates that ive not seen before
1 says only VILLIERS and adress
the other SAYS ONLY the spec MK10 and the V engine and then a box with 3/35 in it all the other marking are not as on the numerous other villiers
they are just the serial number over were the EG a44a45/ 4-45 and then it works out as the month year
IVE READ SOMWERE that villiers made engines for the army and they were marked as a V engine
and it also has the extra long coil like the wx11 wahs have
can you help with anything on it im doing a post later if you wish to post
thanks kev
Re: VILLIERS 4 STROKE MK 10 PRODUCTION PERIOD ???????????
Post by Guest on Fri Sep 16 2011, 08:14
Production of the Mk 10 started in 1941
The Mk12 is a larger capacity Mk10
The V engines were supplied to the military for use, I think they were used on Gensets and Compressors, they were also fitted with the model V carb, the V engine wasnt fitted with the latter B2 carb
Plus the stuff I mentioned on in the PM.
Post by kevjhnsn on Sat Sep 17 2011, 12:54
hi there
yesnthis has the villiers v carb or the also nown as the cm365 carb massive in size to the engine as same carb design as fitted to the mk20 25s
thanks for that how do you find these things ive been looking for a week and must be in the wrong keyword way
thanks kev
