JAP J.A.P. Model 5 rebuild - advice welcome.
Hello all.
I am on a mission to help out a local cricket club and resurrect an old Ransomes 40" mower. They have removed the blades and want to use it as a roller as it is pretty big and heavy.
And so I acquired a JAP Model 5 from an old Dennis mower - complete with clutch and matching 3 point connection bolt holes. Previous owner swears he de-coked and cleaned out the sump and blamed a slightly lumpy running noise on the clutch system flopping around as it wasn't under a load.
What a lod of tosh that was - got brave and dismantled the engine. Thick sludge in sump, no de-coke activity at all and Big end shells completely shot.
Apart from that the engine and cogs and conrod all look really good. Now waiting on a few web enquiries to get correct bearings
Bottom End Shells. Coded 020 4500 (and in case it is relevant... Conrod number. 18480f. )
I know someone that thinks they have these and so I have asked for matching top end bearing and gasket set whilst everything is apart.
Now - questions......
1) Can anyone recommend a reliable supplier of these bearings? and gaskets?
2) The current carb is an AMAL 418. This is a little cracked where the port fits to the governor butterfly chamber (The botterfly governor chamber is separate. - so... Which alternative carbs could I use?
Thanks for any advice
Jev- I really need to post more
JAP gaskets and bearings & another question - governor
Hi.
In case it is of use to anyone else I found a company that was able to press fit my JAP top end bearing and supply new bottom end shells.
Their website is currently down but will be back soon.
http://www.coxandturner.co.uk
CAN ANYONE advise me about the governor on the JAP engines? The arm on mine moves back and forwards freely and opens and closes the inlet flap to block off the carb and kill the engine if you press it by hand. However, it is so loose that the adjustable spring loaded piston can easily push the arm right back when running - thereby stopping the arm returning back to a closed position. Can anyone help?
https://i.servimg.com/u/f39/18/85/51/23/_5811.jpg
» Advice needed on Stuart.
» After the Forums Advice
» Petter A1 Advice please
» Lister A advice
» Lister Engine - Any Advice?
» Lister A advice
