Painting engines
+5
ruston1942
Garak
georgineer
Jonboy
9 posters
Painting engines
Hi again,
I wanted to know what make of paint you use to paint your engine.
I had a few tins of hammerite that I thought I could use, but it seems that is doesn’t gave a very high temperature resistance.
I have brought a tin of tractol paint that I can use in mid Brunswick green, to do my luster D in.
In a 2nd point about painting, what do you do with the inside of the water jacket on a lister to stop it rusting away? Is there a paint that is water proof and can do the high temp needed? I don’t want to paint a nice engine and then see a rusty hole where the water sits.
Any suggestions to either question?
Jonboy- Born to be wild
Re: Painting engines
Stationary Engine Parts have some useful advice on painting and supply paint.
https://www.stationaryengineparts.com/Painting-Advice.html
I would be loth to paint or otherwise coat the inside of a water jacket because once the water gets under the coating - and it will - the coating becomes another source of detritus to clog things up. Better in my opinion to add antifreeze to the cooling water; it has anti-corrosion properties as well as protecting against the cold.
George
George
georgineer- Born to be wild
Jonboy wrote:Hi again,
A couple of squirts of oil into the hot water when the engine is up to temperature will coat the inside of the hopper when the water is drained.
Garak- Life Member
painting engines
Garak wrote:Jonboy wrote:Hi again,
I find TEA BAGS do a great job in the hopper they leave a coating of Tanning on the jacket.
It looks a good brew when draining down but never tasted it as yet,but you could be the first.
John
Amanco chore Boy,Lister DK, Petter W1,Ruston Hornsby PBs,PTs and ZPR bailer model.1900's Millars Falls metal work saw.Austin Seven Chummy's.
ruston1942- Born to be wild
Totally agree with tea bags, as suggested put them in the hopper and run the engine for the rally, the tannin will coat the hopper, preserved steam locomotive's use a similar substance to protect the inside of the boilers.
If using tea bags in a Lister D hopper then put some suitably fine wire mesh over the bars at the bottom of the main hopper, or the tea bags could drop between them into the chamber below and be a right b*gger to get out again!
Jules.
I hang muslin bags filled with tea bags in the hoppers of my Listers, saves fishing around trying to remove them.
I put eggs in mine, can't stand tea and after a few minutes a nice hard boiled egg for dinner.
The use of tea bags in the hopper as a rust treatment is interesting. I have not seen this being done before. Do you see an oily coating on the inside of the hopper or does the liquid chemically react with the rust (is the inside black or blue/black after the tea treatment instead of the orange rust colour)? Chemicals such as phosphoric acid or tannic acid contained in proprietary rust treatments react with the iron oxide converting it to an insoluble black coating of iron phosphate or iron tannate respectively protecting the surface from rusting further. There is no tannic acid in tea but other tannins are present as mentioned above and possibly these are reacting with the rust in a similar way. Sorry to get distracted from the theme of the thread!
PetterAS- Born to be wild
