Amanco serial Numbers
Does the letter T after a serial number on an Amanco Hired Man have any significance?
1945ruston- Born to be wild
Re: Amanco serial Numbers
Think it means it had coil ignition rather than a mag, could be miles out tho.
Thanks for that
Villiers wrote:Think it means it had coil ignition rather than a mag, could be miles out tho.
I'm not sure about that, Rob.
I was going to suggest that the "T" meant a throttle governed Hired Man engine, but that's probably wrong too.
....and maybe not all throttle governed engines had it either.
Maybe 1945ruston can confirm if he has a throttler or a hit 'n miss engine.
A few Amanco oversize 4 and 6hp engines have an "A" after the number, but no one seems to know what that means either.
Thanks, this makes a lot of sense as it is a throttle governed engine
Well that's a possibility then, but I can't say for sure 100% if it's right.
[quote="blue cat"][quote="Villiers"]Think it means it had coil ignition rather than a mag, could be miles out tho.
[/quote]
A few Amanco oversize 4 and 6hp engines have an "A" after the number, but no one seems to know what that means either.[/quote]
Could also mean Tank cooled Philip, seen one of those before now....
[/quote]
Yep, anything is possible, and nothing is certain in this game.
There is 3hp Amanco pictured in SEM May 2019 with the serial number 502983T. It is a throttle governed engine.
Thanks for that, mine is throttle controlled so that makes sense
» Lister D Radiator and Fan conversion
» another petter a1.
» fowler serial no location help
» How / Is it possible to date a Lister D from the casting numbers?
» Never seen a serial number stamped here before.
