Lister D - Pully Grub Screw
Any tips on removing very rusty grub screw - have tried penetrating oil and a good blast with a blow torch to get it very hot - but remains solid and my Allen keys just bend.
I could try to drill out but think made of very hard steel and drill won't touch it.
I don't actually need to remove the pully but the gib key sticks out too far and could catch on clothing etc so not very safe ( and looks not very good) so I need to remove the grub screw and then try to remove the gib key and file down so it fits in further.
northernboy- Born to be wild
Re: Lister D - Pully Grub Screw
drill it it will come out, its the wrong key for the pulley and it should be a parallel key, keep the drill well lubricated and sharp.
OK - I will get some cobalt drills and try again at drilling - do you happen to know what size this grub screw will be ??
Thanks for the advice on the Key.
It will be Whitworth but as to the diameter I don't know, you may just get a caliper on it to measure or eye it up to a drill bit by standing the drill shank on the screw head.
Hi there, I had a similar problem with grub screw on a lister d pulley, I bought myself a set of drills from screwfix, they are brilliant, drilled grub screw out in seconds. They were not cheap but you get what you pay for!
https://www.screwfix.com/p/milwaukee-straight-shank-thunderweb-hss-g-metal-drill-bit-set-19-piece-set/552fj
Thanks - I bought some cobalt drills from Toolstation -(https://www.toolstation.com/cobalt-pro-drill-bit-set/p68884) expensive but hardly touched the grubscrew - I don't know what it is made of but is extremely hard.
I have managed to get the Gib key out with a lot of patience - it is a parallel key but is now well damaged so will be binned and will get a new one. It was just too long and was up against the flywheel gib key so would never have gone in further.
I have also got the pully off with a lot of pulling, lubricating, hammering, heating and cursing
I will try to drill out the grub screw using my pillar drill and freshly sharpened drills - otherwise my be easier and cheaper to try and find another pully.
I drilled out a head stud with my drill bits today and I was very surprised how easy it was. Head studs can be fairly hard!
I also had success - getting the pillar drill onto the screw did the job, slower speed but more force and lots of oil. Managed to re tap the hole and now have a 3/8 unf bolt with a locking nut to nip up the key.
That's great, sometimes just another angle and perseverance is all it needs!
I'm surprised it had a grub screw, most of the pulleys I've had and seen have had a square headed bolt.
» lister d gibkey/pully issues
» Lister belt Pully Removal
» Lister Domestic Water pump - air chamber bleed screw (?)
» Lucas SR2 - locking screw for the impulse body
» Knowledge request - Petter M type 4HP Mixture screw
