Petter AVA1
Petter AVA1
Hi all, anyone got loads of pictures of a working example? Just to reference mines OK there's a small brass pipe below the, I'm assuming, fuel pump where the fuel tank pipe goes into, that seems to have been cut off, would this have any kind of fuel return?
Also, my flywheel will rotate a full 1 1/2 turns each way then stop dead. Looking at the valves there both closed at the time so I'm assuming it cannot be hitting the piston. I tried with the little lever at the top to open the one valve and it still does it.
Thank you
Thank you
AcidK1- Born to be wild
» Petter AVA1.
» Petter AVA1 Series 1 or 2
» Lister D and Petter AVA1
» PETTER M
» Petter AVA1 Oil Feed Pipes Position
» PETTER M
