Sump Flushing
Sump Flushing
Time to change the oil in my project Petter PAZ 1
When I checked I thought that the oil looked quite clean then I realised that it had been standing for a long time and all of the muck has settled out in the sump.
As I use White Spirit as a parts cleaner/de-greaser and have quite a stock of the stuff so is it OK to use it to flush the junk out after a little light scrubbing?
What do folk here use for this purpose?
I did start the engine in the workshop briefly the other day and it ran well. I solved a 'no compression issue' by cleaning out the exhaust port which was almost blocked with carbon and re-ground both valves and after bleeding the fuel system it started right up.
Garak- Life Member
Re: Sump Flushing
I drain the oil until most is removed then use old rags to clean up and then wash out with a little petrol or white spirit.
Re: Sump Flushing
The woodwork department of my shed generates plenty of sawdust/shavings so I use that to mop up the excess after draining and then clean with turps or paraffin
Re: Sump Flushing
After draining the oil from the sump I was left with a black jelly type sludge in the sump. I scraped out as much as I could through the drain plug hole. I then poured some white spirit into the sump which I left overnight to dissolve the remaining gunk before a final drain.
Now time to remove the gauze oil strainer. The job is made more difficult for me as I have large hands and find it almost impossible to get my hand through the crankcase inspection cover, this is made even more difficult as the crankshaft (even in the TDC position) occupies a lot of space. Unfortunately I ended up damaging the strainer during it's removal, so I'm going to re-build the strainer using some brass mess filter sheet (not steel wire mesh like the original). As I had some brass mesh already (not the size I intend to use in the end as it's too fine and would easily clog-up) I decided to make a trial strainer to sharpen up my soldering skills. I think it turned out not too bad. I now await the correct size mesh too arrive to finish the job.
Oops
Mock-up only. The mesh will be replaced with a more open weave type
Oops
Garak- Life Member
Re: Sump Flushing
Nice work.
Re: Sump Flushing
Excellent.!
As for fitting - invite some kids round for Christmas dinner. Their parents will love seeing them covered in oil and grease.
» My new toy my jap 2a
» Lister D sump oil capacity
» Lister D water in sump
» Petter A1 sump oil ???? what grade / type please
» Villiers Mk10 sump removal
