Solex carb
Solex carb
Hi, got a solex carb on my eg1 which when the fuel tap is turned on seems to leak petrol all over what is the best way to stop it. its not poring out but the carb gets wet all over the bottom 1/2.
bamfordlad
bamfordlad
Bamfordlad- Expert
Re: Solex carb
Could it be a fibre washer gone? Or petrol tracking down the pipe caused by a leaky tap?
Lister John- A credit to the forum
Re: Solex carb
the tap is not leaking the pipe is dry. the end of the pipe that fits to the carb has had new washers (red cardboardy things) and there is no visible leak. it appears to be coming out of the join were the bowl meets the top bit.
bamfordlad
bamfordlad
Bamfordlad- Expert
Re: Solex carb
Was going to say try flattening off the carb joints and some new gaskets.
Cheers, Steve
Cheers, Steve
Re: Solex carb
Sounds like the float needle isn't shuting the fuel off when the carb is full, if that is the case, undo the two screws on the top, above the float there is a little needle that fits into a brass nut like bit, give this a twist, grinding paste might help then clean everything up and re assemble.
» Solex 26 FV on Coborn C3
» Solex carb
» SOLEX FH Carburettor #
» Solex Carburettor
» Solex 26 FH Carburettor
» Solex carb
» Solex Carburettor
