bsa is now under the running and ready for the painting to begin
+6
YorkshireChugger
DanBoy
10 posters
Page 1 of 5
Page 1 of 5 • 1, 2, 3, 4, 5
my bsa 120cc was fired up on video on furum last week , and ive got the villiers 1944 tin work to near finished
so the bsa is moving back to shed 1 for the clean up and repaint as ive desided that 2 yrs more on this tinwork and the holes will start
so off with the old and on with the new
watch this space as will be nacked in 48hrs ,if all goes well
Re: bsa is now under the running and ready for the painting to begin
sound like you been bizzy mate...
keep it up feller....
mike....
mike....
yeah mike
as the old saying goes
"MAKING HAY WHILE THE SUN SHINES"
theres not that many of the BSAs around still like other aircooled engines
so will be preserving rather than letting it perrish
some will be going up for sale before to long,
as some i have more than one or two of the same specs and model
as i will be making room for more projects of course
Good to hear your keeping yourself busy Kev sounds like your doing an engine restoration marathon.
I think he's being sponsored by 'sports relief'
DanBoy- Life Member
DanBoy wrote:I think he's being sponsored by 'sports relief'
Or Shell.
stu and danboy
im hoping the engines will do all the running for me
well the bsa had a last fire up before photos and work started and added new fuel and turned tap on choked and pulled once
and away she went no smoke at all so the deglaze and valves grind has defo done its job as it smoked its bits off and kept oiling the plug up before
so well happy again with my engine diy work
anyway this is what ive done out side tonight follows
this is the stat of the paint work now
p.s more to follow soon as
this is what colour the block is originaly almost wolseley battleship grey but its admiralty grey
and the tin work is the colour i painted the villiers plaque with as a tester manchester red
then i got the tin work tank flywheel and flywheel mag electrics backplate off
ect ect
this shows my dodgy soldering skills and cable making as i recoiled and made all new wiring and soldered the ht lead to coil
when i bought it before this final tarting up as if its a runner its worth a coat of paint if needed i wont a cant afford to waste money on fillers primmers and topcoats for a scrapper/ breaker for ebay ect
this photo shows the oil seal is ducked due to hay being pulled down the back of flat belt pulley and forced through the oil seal the seal internal retention
spring is snapped so new seal will be bought before reasembly "WHEN IN ROME AND ALL THINGS LIKE THAT,WHY STRIP TWICE WHEN THE FIRST TIME YOU COULD OF DONE IT WRITE
ect ect
will add the photos of the reduction box later as shed shut up and photos are sh t of some parts
Nice work Kev, great pics, keep us up to date with it's progress. I was wondering where will you get an oil seal from?
stu
the good old company of bearingboys they do loads of stuff
if i need somthing for the hobby i try there search box with key words to item and 8 out of ten they have it
somtimes to expensive ie tools but seals gears trolley wheels and also bearings
found them about 4 yrs ago and keep going back for more quick delivery too usually within 2 days
p.s stu did you find the a1vo book do you have anything for the bsa stats ???
Kev, thanks for the info on the seals, I don't know anything about a book, when did you ask me?
stu
its me getting confususe for a change not you
it was a jap engine manual you offered me lol
heres what ive done today
bet er inside is pleased your using the washing line
coming along nicley Kev
Nice, but darn, you're responsible for me now whistling "hang out the washing on the seigfreid line".
she dont mind me using it and a night they are hanging up in the shed and the bathroom and somtimes on smaller parts i hang in kitchen to dry,harden off
im looky me thinks
im looky me thinks
cure rusted last evening, sanded ,flatend of this lunchtime and just finished the 4th coat of primmer on the block,pulley and other bits
going back out now for sanding the tinwork over again
just stripped and cleaned evry last piece in the carb
i gave it a quick clean before fire up but run it with 2 stroke and loads of redex
and the amount of chalky desolved corrosion crap stuck onto everthing and 1/4 the way up the fuel bowl
so it should run smoother again fingers crossed ,tap and tank to be clean later tonight
and tomorow will be a quite engine day as im doing a driving run for brass for my next projects
Kev..
i think you need to change your washing powder mate...
the washing looks a bit grey.....lol.lol.
thanks mike
trust you as always lol
if i had a shed like yours it would be getting greyer by now lol
im already there mate..lol
my teeth are gone as well...
no hope for me feller...
I find that the worst part of painting is where to put the parts to dry looks like you've got that sorted Kev, think I need a washing line.
Page 1 of 5
