Lister N Type 6 HP Governor Problem
Hi everybody,
Over the last couple of years I have been rebuilding a 6 hp Lister N engine but find I have a problem with the governor appearing not to operate at all as the engine just races away when started, I have rigged up a spring to hold the throttle slide closed which has to be hooked on to a bracket fixed on to the bottom carburetter bolt as soon as the engine starts when it will then run at a steady rate. I have had a look at weights on the camshaft gear wheel which are both free to operate and the double collar on the camshaft is free to slide along the shaft, the throttle operating arm with the two rollers engages in the groove on the camshaft collar OK. This problem puzzles me as everything appears to be free to operate with no restriction. Has anyone else had this problem and can they possibly advise me what I can do next.
Kind regards Scotty
Kind regards Scotty
Scotty- I really need to post more
» Lister D Governor
» Lister D governor question
» Lister D Governor removal
» Lister D governor oiler wick.
» Basic governor settings Lister D
